Софт - программы, прошивки, настройки, ошибки (Vision,Vision+)
#401 OFFLINE
Отправлено 13 августа 2015 - 09:37
#402 OFFLINE
Отправлено 13 августа 2015 - 10:01
я решил данную проблему так (6+):
1) включаю приложение dji vision
2) перехожу в фпв ( загружается карта по lte)
3) потом присоединяюсь к фантику по wifi
4) перехожу в фпв и карта уже там
#403 OFFLINE
Отправлено 30 августа 2015 - 08:31
Кому интересно - ссылка на регистрацию ниже:
Hi all!
We released Litchi's 2.0 beta version today, if you are interested you can sign up for beta at http://flylitchi.com/beta
Litchi 2.0 is compatible with the P2V, P2V+, P3A, P3P, and Inspire1.
Please note that some of the new features are only available for the more advanced aircrafts (P3/I1).
Feature Highlights:
Advanced Ground Station editor allowing you to setup classic missions as well as Cable Cams (P3/I1 only), Selfies (P3/I1 only), Panoramas (P3/I1 only), with real time controls (P3/I1 only)
Virtual Reality mode compatible with most mobile VR goggles such as Freefly VR, Durovis, Homido, Gear VR, etc
Head Tracking in VR mode, including yaw for the Inspire 1
Follow me with advanced settings and real time controls
Option to use external mobile device as Follow me target by using Litchi Magic Leash (Litchi Magic Leash - Android Apps on Google Play), this means you don't have to carry the RC around with you (P3/I1 only)
Follow touch mode, place a marker anywhere on the map, drag it around and the aircraft will follow it
Orbit mode with advanced settings and real time controls
Ability to save and load Ground Station missions and Orbit flights
Course Lock / Home Lock (P3/I1 only)
Auto record
Choice between Hardware and Software Video decoder (P3/I1 only)
Human Readable flight logs (compatible with Dashware's Flytrex profile)
Maximum altitude setting allowing more than 500m (P3/I1 only)
#404 OFFLINE
Отправлено 30 августа 2015 - 09:39
#405 OFFLINE
Отправлено 28 сентября 2015 - 01:28
Кажись я накрыл свой фантик. В виду проблем с критической ошибкой камеры, начитавшись иностранных форумов и ютубов, сделал хард ресет, но он завершился с ошибкой. Теперь при включении, без подсветки пищит как при прошивке, usb компьютер отказывается воспринимать, повторные перепрошивки дают сбой уже на самой начальной стадии. Вот и пришел конец. Теперь вообще не знаю что делать. Куда его нести на восстановление?
#406 OFFLINE
Отправлено 28 сентября 2015 - 01:34
ну либо где покупали, либо у нас на форуме тоже сервис есть Клубная мастерская по ремонту коптеров, запчасти +7 (925) 264-1251 (gopromarket.ru, с 10:00 до 19:00)
#407 OFFLINE
Отправлено 28 сентября 2015 - 01:57
olegnsk, Спасибо, записал. Случилось что-то невероятное, это существо, под названием vision+, по другому не назовешь, живет по своим физическим законам. Сегодня утром решил просто включить его. Он взял как ни в чем не бывало произвел штатный запуск с тестом, сам прошил себе камеру, т.к. там с прошлого дня флешка с прошивкой стояла (на которую раньше он не реагировал). Я подключил телефон, все показал как надо, как будто ничего и не происходило.... Он (лучше ОНА) вчера вымотал(а) весь мозг!!! А сегодня типа: "Кто, я?... Не, не помню..." Вопрос: Что это было и как это понимать??? Пойду приклею ему вместо красных - розовые стикеры!!! Они больше подойдут!!!
Сообщение отредактировал vasteg: 28 сентября 2015 - 01:59
#408 OFFLINE
Отправлено 28 сентября 2015 - 04:00
Информация для FAQ. Если при использовании приложения DJI Vision на Android возникает ошибка "Request Timeout", то для залогинивания можно использовать логин "DJI", пароль "1234".
#409 OFFLINE
Отправлено 04 октября 2015 - 10:51
Да к стате голосовые сообщения тоже на русском
#410 OFFLINE
Отправлено 05 октября 2015 - 12:52
Всех приветствую.
Вопрос к тем, кто использует autopilot от autoflightlogic точка com.
Суть вопроса, купил данную прилажуху, поставил на ipad mini, попробовал режим "орбит" (5 тестовых полетов в комплекте, далее покупать за 200 с чем то руб.). Совершил полет с земли, т.е. запустил приложение, поймал законнектился с фантиком, дождался спутников и т.д., короче, включил режим "орбит", нажал старт, прога еще кое-что уточнила и квадрик начал подниматься с земли в воздух, правда рывками и начал выполнять миссию - облет вокруг меня на удалении от меня 25 метров и на высоте 30 метров.
Теперь о проблемах, которые возникли во время выполнении миссии:
1. В середине миссии прилажуха вылетела, повторный запуск не помог, она не законнектилась с квадриком, хорошо я быстро сориентировался и переключился в мануал, а потом посадил фантик.
2. Посмотрел после полета на компе видео полета и заметил, что нет плавности облета точки, видно как резко поворачивается квадрик по отношению к объекту съемки.
Хотел уточнить у тех, кто юзает данную программу, как осуществляете запуск квадрика в режиме "орбит" с земли или уже в воздухе?
Ну и в целом хотел бы обсудить данную прогу с теми кто летают на визион+.
ПС. Кажется ЮХа использует автопилот.
#411 OFFLINE
Отправлено 05 октября 2015 - 04:55
Нет, не использую. Не смог понять принципа. Тем более, что сразу предупреждают о необходимости приобретения планшета с альтиметром. В самом начале там калибровка планшет-коптер. Типа, прописываются высоты. На моём айпад мини 3 альтиметр не предуспотрен. Может быть поэтому коптер при движении по орбите теряет высоту.
Забил...
#412 OFFLINE
Отправлено 18 октября 2015 - 04:21
Обновил Litchi до 2.2.2, а потом до 2.4.2 - стал неактивен ползунок наклона камеры. При запуске программы он на секунду появляется, потом становится светло-серым и не реагирует на касания. В штатном приложении DJI VISION всё нормально. Что предпринять, чтобы ползунок заработал в Litchi?
#413 OFFLINE
Отправлено 18 октября 2015 - 04:31
RockMeister, в личи же просто по экрану в любой точке касаешься и не отрывая пальца проводишь вверх или вниз и камера повторяет движение пальца
#414 OFFLINE
Отправлено 18 октября 2015 - 04:40
Спасибо! а я в прошлой версии целился в малюсенькие точки
#415 OFFLINE
Отправлено 19 октября 2015 - 12:42
Всем привет!
Вопрос о максимальной высоте: поставил в настройках ограничение в 250м. но коптер не взлетает вышел 120 - выдает "достигнута максимальная высота", причем пробовал и в чистых полях на различных немалых удалениях от городов-аэропортов и вообще ото всего, так и недалеко от города - одно и то же выдает.
Кто знает, подскажите, куда копать?
DJI Phantom 2 Vision+ 2.0 ver.3 все штатное, не перепрошивался. ПО - штатное от DJI на андроиде. Нареканий по полетам ниже 120 метров нет...
#416 OFFLINE
Отправлено 01 ноября 2015 - 04:32
К сожалению на данном этапе в Litchi режим автоматической панорамной съемки на коптере P2V+ не фукционирует. Пробовал запускать, но коптер ничего не фотографирует. Очень жаль. Так хотелось, чтобы он снимал панораму на автомате. Возможно разработчик сможет активировать Пано и на нашем коптере, но пока увы.
#417 OFFLINE
Отправлено 02 ноября 2015 - 04:38
Сегдня выпустили новую версию 2.5.1
Нужно будет проверить режим Облета, до этого Ф.в+ у меня не хотел делать облет.
#418 OFFLINE
Отправлено 03 ноября 2015 - 01:38
В 2.5.1 у меня P2V+ начал снимать панораму в автоматическом режиме
#419 OFFLINE
Отправлено 03 ноября 2015 - 02:03
надо завтра пробовать, сколько по времени занимает съемка ?
#420 OFFLINE
Отправлено 04 ноября 2015 - 01:41
kvadrotema, в автомате снимает ДОЛГО. Сфера из 18 снимков - 4 мин 30 сек. сфера из 14 снимков - 3 мин. 30 сек.
Я в ручном режиме намного быстрее сниму.
Темы с аналогичным тегами Phantom2 Vision, Phantom2 Vision+, софт, программа, ассистент, прошивка, настройки, ошибки
Настройки фото и видео. Постобработка и прочее. (Mavic 2 Pro, Mavic 2 Zoom)Автор Poster1 , 25 авг 2018 фото, видео, настройки, камеры и 1 еще... |
