Litchi for DJI Drones
litchi
Сообщений в теме: 1249
  #1 OFFLINE   LeonSh
LeonSh
  • 59 сообщений
Отправлено 31 August 2015 - 04:28 PM
Записывайтесь на бета тест http://flylitchi.com/beta
Из обещанных плюшек:
Litchi 2.0 is compatible with the P2V, P2V+, P3A, P3P, and Inspire1.
Please note that some of the new features are only available for the more advanced aircrafts (P3/I1).
Feature Highlights:
  • Advanced Ground Station editor allowing you to setup classic missions as well as Cable Cams (P3/I1 only), Selfies (P3/I1 only), Panoramas (P3/I1 only), with real time controls  (P3/I1 only)
  • Virtual Reality mode compatible with most mobile VR goggles such as Freefly VR, Durovis, Homido, Gear VR, etc
  • Head Tracking in VR mode, including yaw for the Inspire 1
  • Follow me with advanced settings and real time controls
  • Option to use external mobile device as Follow me target by using Litchi Magic Leash (Litchi Magic Leash - Android Apps on Google Play), this means you don't have to carry the RC around with you (P3/I1 only)
  • Follow touch mode, place a marker anywhere on the map, drag it around and the aircraft will follow it
  • Orbit mode with advanced settings and real time controls
  • Ability to save and load Ground Station missions and Orbit flights
  • Course Lock / Home Lock (P3/I1 only)
  • Auto record
  • Choice between Hardware and Software Video decoder (P3/I1 only)
  • Human Readable flight logs (compatible with Dashware's Flytrex profile)
  • Maximum altitude setting allowing more than 500m (P3/I1 only)
  #2 OFFLINE   vik2010
vik2010
  • 11 сообщений
Отправлено 31 August 2015 - 06:57 PM
svoemesto,
Я тоже записался, письмо пришло.
Но они пишут, что если ранее не была приобретена Litchi для Фантика 2, то необходимо ее купить.
А потом можно свободно бетатестить.
С маркета скачал бетку. При первом запуске хочет коннект в сеть и требует пин-код.
Уперся в то, что не могу купить - то нет подходящих устройств, то страна не подходит.
  #3 OFFLINE   svoemesto
svoemesto
  • 495 сообщений
Отправлено 31 August 2015 - 06:58 PM
Записался, но чего-то письмо с активационным линком не пришло еще.
Письмо пришло, активировался, сказали "Ждите инструкций"
  #4 OFFLINE   svoemesto
svoemesto
  • 495 сообщений
Отправлено 31 August 2015 - 06:59 PM
Она у меня куплена.
  #5 OFFLINE   svoemesto
svoemesto
  • 495 сообщений
Отправлено 31 August 2015 - 09:30 PM
В режиме камеры, я говорю про режим редактора - это средняя иконка в начальном окне.
А, понял. Да, там нельзя. Только "на месте".
Потыкал немного в Lichi
Не летал еще, естественно.
Но если будет работать как задумано - порвёт UF как тузик грелку. Просто в клочья.
В ближайшие дни по возможности времени/погоды буду тестировать с записью телеметрии.
  #6 OFFLINE   EGORka
EGORka
  • 245 сообщений
Отправлено 01 September 2015 - 09:45 AM
Я немножко не понял -
      If you already have Litchi for DJI Phantom 2 installed on your device, you'll get an update with the beta version shortly. If you don't have Litchi for DJI Phantom 2 installed, download it on Google Play first, then you'll get an update with the beta version. It can take a few hours for the beta update to arrive.
Т.е. надо купить версию для фантома 2 и ждать апдейта до беты ?
  #7 OFFLINE   svoemesto
svoemesto
  • 495 сообщений
Отправлено 01 September 2015 - 09:52 AM
Насколько я понял алгоритма такой:
- покупаешь программу, устанавливаешь
- регистрируешся как бета-тестер
- когда зарегистрируешся и об этом пройдет обновления в базе данных - тебе будут приходить бета-обновления стандартно, через плеймаркет.
  #8 OFFLINE   EGORka
EGORka
  • 245 сообщений
Отправлено 01 September 2015 - 11:15 AM
как бета тестер я зарегился. вот после и пришло это сообщение. Ладно , погнал покупать. :)
Сообщение отредактировал EGORka: 01 September 2015 - 11:15 AM
  #9 OFFLINE   serj20021
serj20021
  • 33 сообщений
Отправлено 01 September 2015 - 04:51 PM
только зарегистрировался и уже пришли ссылки на скачивание.
  #10 OFFLINE   svoemesto
svoemesto
  • 495 сообщений
Отправлено 01 September 2015 - 06:25 PM
Оттестировал сегодня Личи во всех режимах.
Подвела программа записи с экрана - сглючила и не записала. Так что видео телеметрии нет.
Посмотрю что записалось с ГоПро на бошке, но не уверен что там хорошо будет видно.
Видимо придется еще раз отлетать, под запись.
Вкратце - я в восторге. Все работает как надо и даже лучше. Несколько мелких глюков впечатление не испортили.
  #11 OFFLINE   EGORka
EGORka
  • 245 сообщений
Отправлено 01 September 2015 - 09:09 PM
При включеной в меню опции "Autorecord", я понял это старт записи видео с запуском коптера, может остановить видео и сделать фотографию ?
Мне пока не пришло ничего, на емейл ответил ответил.  Вот что пришло на почту:
Сообщение отредактировал EGORka: 01 September 2015 - 09:20 PM
  #12 OFFLINE   LeonSh
LeonSh
  • 59 сообщений
Отправлено 01 September 2015 - 09:26 PM
EGORka, вам нужно сейчас скачать программу в плеймаркете, вы уже являетесь бетта тестером
svoemesto, а я сразу говорил, что Литчи - это лучшая программа для фантомов.
  #13 OFFLINE   svoemesto
svoemesto
  • 495 сообщений
Отправлено 01 September 2015 - 10:07 PM
Сегодня я в этом убедился сам!
  #14 OFFLINE   EGORka
EGORka
  • 245 сообщений
Отправлено 01 September 2015 - 10:18 PM
Так она у меня установлена. но для Фантома 2. Насколько я понял на почту должна прийти ссылка на бету для  Phantom3/Inspire 1.
Сообщение отредактировал EGORka: 01 September 2015 - 10:28 PM
  #15 OFFLINE   svoemesto
svoemesto
  • 495 сообщений
Отправлено 01 September 2015 - 10:19 PM
а ты обнови с маркета и запусти. при первом старте у меня попросила выбрать модель коптера, Р3Р присутствовал.
  #16 OFFLINE   svoemesto
svoemesto
  • 495 сообщений
Отправлено 01 September 2015 - 10:45 PM
Жду погоду и выходные.
Если завтра с погодой будет порядок - попрбую еще раз записать с телеметрией обзор.
  #17 OFFLINE   sasha632
sasha632
  • 16 сообщений
Отправлено 02 September 2015 - 12:09 AM
svoemesto все ни как не могу понять откуда прошивки качать на inspire ? прогу купил
  #18 OFFLINE   svoemesto
svoemesto
  • 495 сообщений
Отправлено 02 September 2015 - 12:33 AM
если ты зарегился как бета-тестер тебе должна была прийти ссылка откуда качать
  #19 OFFLINE   EGORka
EGORka
  • 245 сообщений
Отправлено 02 September 2015 - 12:41 AM
У Личи я понял онлайн редактор, можно на компе дома  точки пораставлять, но тут беднее по сравнению с Ультимейтом. Только точка, высота  и скорость. Никаких настроек направления камеры нет.. ну и рисовать никак.
  #20 OFFLINE   HiBlack
HiBlack
  • 180 сообщений
Отправлено 02 September 2015 - 02:29 AM
Господа, как передача видео в обсуждаемой программе личи - не тормозит? вылеты программы бывают? картинка качественная передается?
