скиньте сюда лог, разберёмся.
Да нет там ничего интересного кроме того что сказал:
00m 00s 0.0 m 0 m Mode Mode changed to Motors_Started
00m 00s 0.0 m 0 m Tip Setting new Return-To-Home altitude to 100m (328 ft). Data Recorder File Index is 34. Setting new Maximum Flight Altitude to 30m (98 ft)
00m 01s 0.0 m 0 m Mode Mode changed to Assisted_Takeoff
00m 08s 0.0 m 0 m Mode Mode changed to Tripod
00m 10s 0.3 m 0 m Tip Downward Obstacle Sensing is not functioning.__Ambient Light is too weak.
00m 11s 0.5 m 0 m Tip Upward Obstacle Detected (repeated 2 times)
00m 14s 0.6 m 0 m Tip Auxiliary Bottom Light turned on.
00m 16s 0.6 m 0 m Tip Auxiliary Bottom Light turned off.
00m 19s 0.8 m 0 m Mode Mode changed to Atti
00m 19s 1.0 m 0 m Warning Weak GPS signal. Aircraft is in Attitude mode and hovering may be unstable. Fly with caution.
00m 20s 1.1 m 0 m Mode Mode changed to Tripod
00m 22s 1.1 m 0 m Warning 88% Battery at maximum distance
00m 24s 1.1 m 0 m Mode Mode changed to Atti
00m 25s 0.8 m 0 m Warning Weak GPS signal. Aircraft is in Attitude mode and hovering may be unstable. Fly with caution.
00m 26s 0.6 m 0 m Mode Mode changed to Tripod
00m 29s 0.5 m 0 m Mode Mode changed to Atti
00m 30s 0.5 m 0 m Warning Weak GPS signal. Aircraft is in Attitude mode and hovering may be unstable. Fly with caution.
00m 31s 0.5 m 0 m Mode Mode changed to Tripod
00m 33s 0.0 m 0 m Tip Backward Obstacle Sensing is not functioning.__Ambient Light is too weak.
00m 33s -0.1 m 0 m Tip Upward Obstacle Detected
00m 34s -0.6 m 0 m Mode Mode changed to Atti
00m 34s -0.6 m 0 m Tip Backward Obstacle Sensing is not functioning.__Ambient Light is too weak.
00m 34s -0.6 m 0 m Tip Motor current error. Check your propellers and fly with caution.
00m 34s -0.7 m 0 m Warning Not Enough Force/ESC Error (repeated 4 times)
Темнота сзади и внезапный Atti режим
Вот так и выглядит переход на темную сторону
Сообщение отредактировал Fulminata: 17 February 2019 - 12:09 PM
