Dji phantom 3 adv,обновление с ошибкой [19 00] Firmware upgrade finish failed (step = 2, err = 0x08)
  #1 OFFLINE   Blondin
Blondin
Отправлено 23 January 2023 - 04:36 PM
Всем доброго дня! После неудачного обновления коптера связи с коптером нет. Все варианты законнектить пробовал(и через Go и нажатием кнопок на пульте) . Откатывать и повышать прошивку пробовал,не помогает. В логах ошибка по 19 блоку.
[00058171]Waiting for user confirm...
 [00068266]Timeout, start upgrade automatically.
 [00068436]Firmware upgrading[1]...
 [00087052][01 00] Firmware upgrade start...
 [00011737][01 00] Firmware upgrade finished successfully.
 [00012002]Done.
 [00012092]Packet [C:\P3S_FW_V01.09.0060.bin] resumed, card sn [0x00002b0a].
 [00012370]Packet vlink 01.09.0060 <-> 01.08.0080.
 [00012468]Record vlink 00.00.0000 <-> 00.00.0000 (flow = 0).
 [00012564]Version checking[2]...
 [00012692][03 05][00] v34.2.0.9 -> v34.2.0.9
 [00012827][03 06][00] v2.2.6.8 -> v2.4.20.18 need upgrade.
 [00012950][04 00][00] v1.38.0.0 -> v1.44.0.0 need upgrade.
 [00013112][11 00][00] v1.6.0.0 -> v1.8.0.0 need upgrade.
 [00013274][11 01][00] v1.6.0.0 -> v2.0.0.33, firmware v1.6.0.0 not support.
 [00013370][11 01][00] v1.6.0.0 -> v2.0.0.33
 [00013503][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
 [00013646][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
 [00013826][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
 [00013962][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
 [00014053][15 00][00] v1.1.2.0 -> v1.1.2.0
 [00014197][17 00][00] v1.1.1.7 -> v1.1.1.7
 [00014377][17 01][00] v1.0.2.7 -> v1.0.2.7
 [00014504][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
 [00014597][01 00][05] v1.23.4920 -> v1.23.4920
 [00014696][01 01][00] v1.14.3090 -> v1.23.4920 need upgrade
 [00014904][09 00][00] v1.7.0.3 -> v3.0.0.10 need upgrade.
 [00015004]Done.
 [00015094]Firmware upgrading[2]...
 [00015382][01 01] Firmware upgrade start...
 [00045831][01 01] Firmware upgrade finished successfully.
 [00045950][12 00] Firmware upgrade start...
 [00119718][12 00] Firmware upgrade finished successfully.
 [00119834][12 01] Firmware upgrade start...
 [00184944][12 01] Firmware upgrade finished successfully.
 [00185060][12 02] Firmware upgrade start...
 [00247111][12 02] Firmware upgrade finished successfully.
 [00247236][12 03] Firmware upgrade start...
 [00310379][12 03] Firmware upgrade finished successfully.
 [00310494][11 00] Firmware upgrade start...
 [00357922][11 00] Firmware upgrade finished successfully.
 [00358358][03 06] Firmware upgrade start...
 [00720261][03 06] Firmware upgrade finished successfully.
 [00724206][19 00] Firmware upgrade start...
 [00754900][19 00] Firmware upgrade finish failed (step = 2, err = 0x08).
 [00785035][09 00] Firmware upgrade start...
 [00837140][09 00] Firmware upgrade finished successfully.
 [00837275][04 00] Firmware upgrade start...
 [00897163][04 00] Firmware upgrade finished successfully.
 [00897264]Done.
 [00897362]Version checking[3]...
 [00897502][03 05][00] v34.2.0.9 -> v34.2.0.9
 [00897642][03 06][05] v2.4.20.18 -> v2.4.20.18
 [00897786][04 00][05] v1.44.0.0 -> v1.44.0.0
 [00897963][11 00][05] v1.8.0.0 -> v1.8.0.0
 [00898143][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
 [00898238][11 01][00] v1.8.0.0 -> v2.0.0.33
 [00898386][12 00][05] v1.10.0.0 -> v1.10.0.0
 [00898538][12 01][05] v1.10.0.0 -> v1.10.0.0
 [00898690][12 02][05] v1.10.0.0 -> v1.10.0.0
 [00898875][12 03][05] v1.10.0.0 -> v1.10.0.0
 [00898980][15 00][00] v1.1.2.0 -> v1.1.2.0
 [00899132][17 00][00] v1.1.1.7 -> v1.1.1.7
 [00899335][17 01][00] v1.0.2.7 -> v1.0.2.7
 [00899455][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
 [00899554][01 00][05] v1.23.4920 -> v1.23.4920
 [00899654][01 01][05] v1.23.4920 -> v1.23.4920
 [00900516][09 00][05] v3.0.0.10 -> v3.0.0.10
 [00900616]Done.
 [00900706]Firmware upgrading[3]...
 [00904852][19 00] Firmware upgrade start...
 [00935556][19 00] Firmware upgrade finish failed (step = 2, err = 0x08).
 [00965658]Done.
 [00965749]Version checking[4]...
 [00965905][03 05][00] v34.2.0.9 -> v34.2.0.9
 [00966046][03 06][05] v2.4.20.18 -> v2.4.20.18
 [00966147][04 00][05] v1.44.0.0 -> v1.44.0.0
 [00966328][11 00][05] v1.8.0.0 -> v1.8.0.0
 [00966506][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
 [00966602][11 01][00] v1.8.0.0 -> v2.0.0.33
 [00966766][12 00][05] v1.10.0.0 -> v1.10.0.0
 [00966909][12 01][05] v1.10.0.0 -> v1.10.0.0
 [00967061][12 02][05] v1.10.0.0 -> v1.10.0.0
 [00967221][12 03][05] v1.10.0.0 -> v1.10.0.0
 [00967317][15 00][00] v1.1.2.0 -> v1.1.2.0
 [00967455][17 00][00] v1.1.1.7 -> v1.1.1.7
 [00967665][17 01][00] v1.0.2.7 -> v1.0.2.7
 [00967801][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
 [00967899][01 00][05] v1.23.4920 -> v1.23.4920
 [00967994][01 01][05] v1.23.4920 -> v1.23.4920
 [00968101][09 00][05] v3.0.0.10 -> v3.0.0.10
 [00968203]Done.
 [00968298]Firmware upgrading[4]...
 [00972285][19 00] Firmware upgrade start...
 [01002977][19 00] Firmware upgrade finish failed (step = 2, err = 0x08).
 [01033075]Done.
 [01033168]Version checking[5]...
 [01033309][03 05][00] v34.2.0.9 -> v34.2.0.9
 [01033451][03 06][05] v2.4.20.18 -> v2.4.20.18
 [01033559][04 00][05] v1.44.0.0 -> v1.44.0.0
 [01033730][11 00][05] v1.8.0.0 -> v1.8.0.0
 [01033909][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
 [01034000][11 01][00] v1.8.0.0 -> v2.0.0.33
 [01034164][12 00][05] v1.10.0.0 -> v1.10.0.0
 [01034326][12 01][05] v1.10.0.0 -> v1.10.0.0
 [01034484][12 02][05] v1.10.0.0 -> v1.10.0.0
 [01034645][12 03][05] v1.10.0.0 -> v1.10.0.0
 [01034747][15 00][00] v1.1.2.0 -> v1.1.2.0
 [01034898][17 00][00] v1.1.1.7 -> v1.1.1.7
 [01035073][17 01][00] v1.0.2.7 -> v1.0.2.7
 [01035184][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
 [01035367][01 00][05] v1.23.4920 -> v1.23.4920
 [01035465][01 01][05] v1.23.4920 -> v1.23.4920
 [01035583][09 00][05] v3.0.0.10 -> v3.0.0.10
 [01035677]Done.
 [01035776]Firmware upgrading[5]...
 [01039768][19 00] Firmware upgrade start...
 [01070462][19 00] Firmware upgrade finish failed (step = 2, err = 0x08).
 [01100557]Done.
 [01100655]Version checking[6]...
 [01100813][03 05][00] v34.2.0.9 -> v34.2.0.9
 [01100960][03 06][05] v2.4.20.18 -> v2.4.20.18
 [01101061][04 00][05] v1.44.0.0 -> v1.44.0.0
 [01101255][11 00][05] v1.8.0.0 -> v1.8.0.0
 [01101433][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
 [01101532][11 01][00] v1.8.0.0 -> v2.0.0.33
 [01101693][12 00][05] v1.10.0.0 -> v1.10.0.0
 [01101862][12 01][05] v1.10.0.0 -> v1.10.0.0
 [01102023][12 02][05] v1.10.0.0 -> v1.10.0.0
 [01102173][12 03][05] v1.10.0.0 -> v1.10.0.0
 [01102270][15 00][00] v1.1.2.0 -> v1.1.2.0
 [01102423][17 00][00] v1.1.1.7 -> v1.1.1.7
 [01102628][17 01][00] v1.0.2.7 -> v1.0.2.7
 [01102749][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
 [01102850][01 00][05] v1.23.4920 -> v1.23.4920
 [01102946][01 01][05] v1.23.4920 -> v1.23.4920
 [01103067][09 00][05] v3.0.0.10 -> v3.0.0.10
 [01103169]Packet upgrade failed at firmware upgrade.
Теперь собственно вопрос: удалось ли кому-то победить проблему такого типа? Может внутрисхемно прошить можно?  Или хоть круг поиска  неисправного узла сузить поможет кто.
На зарубежных форумах пишут,что это 19 00 -> Air Base Band,а что это и с чем едят,мне не понятно.
Коптер практически новый,налет мизерный,не падал.
 Всем откликнувшимся заранее спасибо!!!
