Typhoon H480
Сообщений в теме: 1744
  #1201 OFFLINE   costarika
costarika
  • 777 сообщений
Отправлено 25 October 2017 - 09:51 AM
информация от иностранцев о наличии возможности убрать No-Fly zones с помощью самой Yuneec - https://yuneecpilots...034/#post-70731
You just need to call them, explain the situation. They will immediately (while you are still on the phone with them) send you a form to fill out which basically indemnifies them from anything stupid you do. You fill it out, scan it and email it back to them. Within about 10-15 min, you receive another email containing a file with instructions. You'll load the file into the GUI software and then install it. You will then have new buttons in the GUI that let you disable the No-Fly Zones or Enable them. You then connect your H to the PC, select Disable No-Fly Zones and save. Then you're good.[/size]
In my case, I fly a lot at an AMA sanctioned Model Aircraft airport that is just 2.5 miles form a Class D airport. This would normally be a No-Fly Zone according to Yuneec's maps but now I can fly there without a problem.[/size]
в атаче к посту - пример инструкции Прикрепленный файл  Typhoon H Complete No Fly Removal Instructions.pdf   627.56К   73 Количество загрузок:
Сообщение отредактировал costarika: 25 October 2017 - 09:54 AM
  #1202 OFFLINE   ACDS
  • 3585 сообщений
Отправлено 25 October 2017 - 11:48 AM
к сему они постоянно во всех практически постах пишут-
Unmanned Aircraft Systems (UAS) Frequently Asked Questions
Option #1. Fly in accordance with the Special Rule for Model Aircraft (Public Law 112-95 Section 336). Under this rule, operators must:
  • Fly for hobby or recreational purposes only
  • Follow a community-based set of safety guidelines
  • Fly the UAS within visual line-of-sight
  • Give way to manned aircraft
  • Provide prior notification to the airport and air traffic control tower, if one is present, when flying within 5 miles of an airport
  • Fly UAS that weigh no more than 55 lbs. unless certified by a community-based organization
  • Register the aircraft (UAS over 0.55 lbs. and less than 55 lbs. can be registered online at registermyuas.faa.gov; UAS 55 lbs. or greater must be registered through the FAA's paper-based process)
  #1203 OFFLINE   BalticVideo
BalticVideo
  • 244 сообщений
  • Коптер:Typhoon H, DJI Inspier 1 Х-5, Phantom 4, Phantom 4 Pro
Отправлено 25 October 2017 - 10:25 PM
S.O.S.  S.O.S.  S.O.S.!!!!!!
Улетел мой Тайфунчик и не вернулся.
Пошёл проверить дальность видео на заменённом передатчике. Взлетел, встал на маршрут, через 150 м видео со штатной "обновлённой" камеры встало и так и стояло до конца полёта. На курсовой камере полетел дальше. На 1400м картинка стала портиться, я дал команду "домой". Коптер развернулся и пошёл обратно. Сразу после этого без видимых причин начал снижаться. Не то, что бы камнем вниз, но довольно бодренько.  Рывок  левым стиком вверх ни чего не дал. Так и приземлился в неизвестном месте.  Батарея была заряжена, воплей о слабом заряде пульт не подавал.Запись не велась, поэтому видео просмотреть не получится. Подскажите, какую полезную информацию в данной ситуёвине можно извлечь из пульта и как это сделать. Поиски ножками и глазками результата не дали.  Площадь возможного приземления 200 Х 400 м на слегка пересечённой местности - травка, мелкие кустики, канавки.  Если удастся узнать место падения поточнее, завтра попробуем с приятелями с коптеров поискать. Уходил с поля уже затемно. Надеюсь ночью его ни кто там не подберёт.
Добавлено позже (25 Октябрь 2017 - 20:12)
Место поиска немного сузилось. В пульте нашёл свой последний полёт. Но не на карте, а на какой-то схеме. Конечная точка обозначена, но без координат. Как эту точку перетащить в какую-нибудь карту с координатами или получить координаты в цифровом виде?
Добавлено позже (25 Октябрь 2017 - 22:25)
Умозрительно перенёс точку падения со схемы в пульте на яндекс-карту и место поиска сузилось до 50х50. Если в таком приземлении не было чьего-то злого умысла. то завтра утром должны его найти. Что-бы в полную темень в непролазные болта кто-то полез случайно, и нашёл коптер, в такое верится с трудом. Либо он там лежит, либо уже нет.
Сообщение отредактировал BalticVideo: 25 October 2017 - 08:31 PM
  #1204 OFFLINE   costarika
costarika
  • 777 сообщений
Отправлено 25 October 2017 - 10:46 PM
Телеметрия лежит в пульте,
В faq пост 4 & 6.
Добавлено позже (25 Октябрь 2017 - 22:46)
И к слову, "поменяли передатчика на камере", видео линк - отвалился (проверка прошла), полетели дальше - решили проверить дальность чего?
  #1205 OFFLINE   BalticVideo
BalticVideo
  • 244 сообщений
Отправлено 25 October 2017 - 11:21 PM
costarika, дальность видео курсовой камеры. К отвалившемуся видеосигналу с камеры я уже привык. На 200 м начинала тормозить а на 400-500 пропадала всегда, даже в чистом поле. Сейчас подумал, что какая-то нестыковка видеопрередатчика от другой камеры или прошивок. Старт и полёт до команды возврата домой были нормальными.
Может быть, всё-таки, эти злосчастные микрики сыграли роль. Если это настройки каналов, а я их понажимал, то каналы сбились, поэтому и дальность 150 метров? Хотя, маловероятно. До этого я менял пульты и камеры неоднократно.....
Добавлено позже (25 Октябрь 2017 - 23:21)
В faq пост 4 & 6.
Простите, а что такое В faq пост 4 & 6. ?
Кое-что я нашёл в File Manager  и Flightlogpars. В картах я кое-как разобрался и точку падения вычислил. А вот с какими-то таблицами что делать?
Или я вообще не туда полез?
Сообщение отредактировал BalticVideo: 25 October 2017 - 11:09 PM
  #1206 OFFLINE   ACDS
  • 3585 сообщений
Отправлено 26 October 2017 - 06:30 AM
BalticVideo
мои сочувствия Вам!
Но не надо так словами кричать - Улетел... улетают Фантики и Мавики, у Вас просто не вернулся по не понятным причинам. Он же не ломанулся на родину..
Вам сюда -   http://airdata.com
Нужно взять логи с пульта и  загрузить на сервис, там и понять можно что случилось ( + - 60\40 ) и карта будет где его последний привет был для пульта.
Сервис этот для джидаев, но и наши логи работают - проверял со своего Тайфуна. Если точнее - не помню.. сейчас попробую сам и дублем напишу. А может и сами сделаете.
Вопрос - а там никакие учения ВС случаем не проводились ?
В батальонных группах сейчас появились какие то цифровые РЛС (работают не по отражающему сигналу, а по потоку данных с борта) , они довольно успешно "присаживают" дрончики.. Радиус действия не знаю, но примерно 5-15 км..
Удачи в поиске!
Добавлено позже (26 Октябрь 2017 - 09:27)
имярек в своем репертуаре  )))
перевод-  посмотрите в Вопросы/Ответы - посты 4 - 6  или как обычно делают в культурных ветках ( :good: ) -
Вам сюда - http://dji-club.ru/i...topic/9778-faq/
Добавлено позже (26 Октябрь 2017 - 10:24)
на airdata у меня кончились бесплатные загрузки..
еще вариант - идете сюда - https://mygeodata.cloud/conversion#
это конвертер  csv  в kml с автоматической проставкой ваших координат в карту - экспортируете свой csv файл из раздела GPS  и получаете точку на карте  с точными координатами (в правом верхнем углу будут координаты стрелки от мышки - наводите на точку Тайфуна и переписываете,затем их можно на гуглу или яндекс карыт вбить и получить точку с фото местности) ,одновременно можете скачать kml  файл.
этот вариант самый быстрый и без регистрации.. Подробнее смотрите на примере костарики ву разделе Вопросов..
на моем примере -
перенос на другую кату , например Гугла - https://www.google.ru/maps
Добавлено позже (26 Октябрь 2017 - 14:30)
Кто что скажет по этим батареям ?
http://www.gifipower...on-h-p-125.html
Сообщение отредактировал magsilver: 26 October 2017 - 02:39 AM
  #1207 OFFLINE   None
None
  • 332 сообщений
Отправлено 26 October 2017 - 07:33 AM
я таких не видел. Но чего то слишком много емкости. Попросите продавца дать вес и станет понятно есть в ней или нет такая емкость.
Добавлено позже (26 Октябрь 2017 - 07:33)
BalticVideo, успешных поисков
  #1208 OFFLINE   ACDS
  • 3585 сообщений
Отправлено 26 October 2017 - 07:35 AM
а если пройти по ссылке - там  650 г.  и цена ниже оригинала..
народ на юинкпайлоте пользуется ( именно про эти нет) этим брендом на Q500 , вроде довольны..
написал, вдруг кто втихаря прикупил и сообщить забыл ))
Сообщение отредактировал magsilver: 26 October 2017 - 07:35 AM
  #1209 OFFLINE   None
None
  • 332 сообщений
Отправлено 26 October 2017 - 10:14 AM
magsilver,650... Блин из бошки вылетело сколько родная, к 10 по мск взвешу оригинал.. Смысл в том, что емкость батареи напрямую зависит от веса. Исходим из того что родная 6000.
Родная Юник 575 грамм с корпусом и платой защиты.
Для - LiPo (литий-полимерные) справедливо следующее:
Плотность энергии (Ватт/кг)=3,7хSхQ/g,
где:
3,7 – это напряжение в вольтах одной банки, входящей в батарею;
S – количество банок в батарее;
Q – емкость батареи в мАч
g – вес батареи в граммах.
Оптимальное значение плотности энергии аккумуляторной батареи для мультикоптера (mikrokopter) должно быть 140.
Но 140 это не догма, может значение незначительно колебаться в пределах - 100 +20
Цифры взяты здесь
ТТХ батареи:
YUNEEC TYPHOON H 8050MAH 4S, 14.8V LIPO BATTERY
Battery Type: Lithium Polymer.
100% Compatible with original Yuneec charger.
High Capacity 8050mah. Longer flying time.
Light weight. Compact design.
Capacity: 4S 14.8v 8050mAh
Weight: about 650g
Сообщение отредактировал None: 26 October 2017 - 10:14 AM
  #1210 OFFLINE   ACDS
  • 3585 сообщений
Отправлено 26 October 2017 - 11:57 AM
ТТХ батареи:
это я и сам прочитал ))
считаем -
П = 3.7 х 4 х 8050 / 650= 183.29
Теперь бы понять , чтобы это значило
Если например взять как примерный образец  Турниги графеновые -
П= 3.7х4х 10000 / 936 = 158.11
или проверил расчеты по другим батареям , получается, как вы пишите. Отсюда можно сделать  один из двух выводом - либо вес больше чем указан, либо емкость меньше..
хмм..
Добавлено позже (26 Октябрь 2017 - 19:53)
или это крутые батареи ))
Добавлено позже (26 Октябрь 2017 - 19:57)
кстати, ссылка интересная, надо попробовать рассчитать полетное время Тайфуна по их графику и описанию расчетов.. насколько реальны расчеты из фактического полетного времени.
  #1211 OFFLINE   BalticVideo
BalticVideo
  • 244 сообщений
Отправлено 26 October 2017 - 12:57 PM
Увы, коптер не нашли.
Сегодня попробуем детальнее поработать с телеметрией и выяснить более точно место падения и завтра съездить на поиски ещё раз. Но шансов почти нет. Искали тщательно, предполагаемое место падения было всего 100-150 на 50. Искали и ножками и глазками и Фантиком. Увы....Даже теоретически не могу представить ни что с ним случилось, ни куда он делся. Видно судьба у него или у меня такая. :sorry:
  #1212 OFFLINE   costarika
costarika
  • 777 сообщений
Отправлено 26 October 2017 - 01:03 PM
вы "привязали" телеметрию к карте?
  #1213 OFFLINE   None
None
  • 332 сообщений
Отправлено 26 October 2017 - 01:13 PM
183.29
это говорит о том, что нет там того что декларируется
бросьте в меня заархивированной папкой с телеметрией
  #1214 OFFLINE   ACDS
  • 3585 сообщений
Отправлено 26 October 2017 - 01:33 PM
достаточно одного csv gps..
в пульте идет разделение по параметрам.. я спецом отдельные папки завел для каждого..
вы смотрели по карте с gps телеметрии по ссылке что я вам дал  ?
  #1215 OFFLINE   BalticVideo
BalticVideo
  • 244 сообщений
Отправлено 26 October 2017 - 01:34 PM
https://yadi.sk/d/Y0lZeCxK3P7Wh2
https://yadi.sk/d/xL3TTdHg3P7WiT
  #1216 OFFLINE   ACDS
  • 3585 сообщений
да, и .. с воздуха другим дроном искать - совершенно бесполезное дело, тем более темный Тайфун  - проверенно опытным путем на белом Фантике ))
  #1217 OFFLINE   None
None
  • 332 сообщений
Отправлено 26 October 2017 - 01:37 PM
BalticVideo, Всю папку вместе с поддиректориями. Там еще статус сенсоров есть.
  #1218 OFFLINE   BalticVideo
BalticVideo
  • 244 сообщений
с телеметрией пока не разобрался. сегодня вечером освоим.
Я открыл пульт и там нашёл свой последний полёт, сопоставил его с яндекс картой на телефоне и сравнительно точно нашёл место падения. Но коптера там не нашёл.
  #1219 OFFLINE   ACDS
  • 3585 сообщений
Отправлено 26 October 2017 - 01:51 PM
по обоим файлам  - вас "сбили"
придется верить на удачу и  Его Величество Случай
Добавлено позже (26 Октябрь 2017 - 21:44)
по обоим файлам вы в одном месте - на дне моря-океяна (
Добавлено позже (26 Октябрь 2017 - 21:48)
а может вы не тот , за кого вы себя выдаете ?  может вы англицкий шпиён и делали разведку Шотландии и утопили в Атлантике дрон ?
это канечно шутька, понимаю , что не к месту - но координаты! - прошу сори )
Добавлено позже (26 Октябрь 2017 - 21:49)
да, забыл ссылки дать -
https://mygeodata.cl...Telemetry_00170
https://mygeodata.cl...Telemetry_00169
Добавлено позже (26 Октябрь 2017 - 21:51)
упссс.... по ссылкам увидел в уменьшенном  масштабе - вы еще и Африку исследовали  - Бискайский залив !
Мдааа.. вас точно "забабахали!"... какой то сержант или прапорщик повеселился..((
Сообщение отредактировал magsilver: 26 October 2017 - 01:53 PM
  #1220 OFFLINE   BalticVideo
BalticVideo
  • 244 сообщений
Отправлено 26 October 2017 - 01:52 PM
BalticVideo,
Оно?
https://yadi.sk/d/bKVMhKRI3P7Ypb
https://yadi.sk/d/eOQOWale3P7Yqq
https://yadi.sk/d/Eu1QIZHc3P7Yuj
