Пульт от MAVIC PRO как нибудь можно подключить?
Симулятор Полётов DJI 2018
#21 OFFLINE
#22 OFFLINE
Отправлено 06 December 2018 - 08:40 AM
Сыровато ещё, но уже само появление радует.
#23 OFFLINE
Отправлено 11 December 2018 - 07:33 PM
Я ставил, пульт от Phantom 4 (правда, иногда пищит, бесит) подключился без проблем. На компе
1) win 10
2) 16 Гб
3) GTX 1070
4) 7700HQ
Сообщение отредактировал WBG: 11 December 2018 - 07:34 PM
#24 OFFLINE
Отправлено 19 December 2018 - 06:45 PM
Подключил пульт от Мавик про .Как переключать режимы полета?
#25 OFFLINE
Отправлено 23 December 2018 - 10:46 PM
Вот видео на Ютубе
So... what you need to do is following: 1.) Download and install DJI Assistant 2 2.) Download and install the DJI Simulator 3.) Deactivate Driver Signature Checking in Windows because the DJI drivers for the Remote are not properly signed so Windows 10 is denying the Installation of needed drivers: So hold SHIFT. Then RIGHT-klick on the Windows Symbol in the TaskBar in the lower left corner. klick on "Shutdown and Log Out" and "Restart" . Now slect "Troubleshoot" and "Advanced Options" and "Startup Settings" and then Click on "Restart" . In the following Menu is showing 9 Startup Options from which you can chose! .You need to chose the option "Disable driver signature enforcement" by pressing "7" on your keyboard. Now Windows is starting without Driver Signature checking. This is only temoporary till the next normal reboot. So, after selecting "7" windows is booting up without dirver signature checking. 4.) Install Drivers: Now connect your supported DJI Remote over USB to your computer. Go into the "Device Manager" of Windows. There you will see one or two new devices with a yellow triangle listed. For me it showed "CDC ACM DATA" as a new device. Right klick on it. Select "Update Driver" and Select the Driver Folder which is located in the "DJI Assistant" Folder where you installed "DJI Assistant". Click on "include all Subfolders" and click on next. Now you will be asked if you really want to install the appropriate drivers. Klick on YES and the drivers will be installed. Now start the Simulator and test if the Remote is working properly. It should. That is what I have done to get my Mavic Air Remote Working with the simulator.
Добавлено позже (24 Декабрь 2018 - 01:41)
Итак, что вам нужно сделать, это: 1.) Скачать и установить DJI Assistant 2 2.) Скачать и установить DJI Simulator 3.) Отключить проверку подписи драйверов в Windows, поскольку драйверы DJI для пульта не подписаны должным образом поэтому Windows 10 запрещает установку необходимых драйверов: так что держите SHIFT. Затем щелкните правой кнопкой мыши на символе Windows в панели задач в левом нижнем углу. нажмите на «Завершение работы и выход из системы» и «Перезагрузка». Теперь выберите «Устранение неполадок», «Дополнительные параметры» и «Параметры запуска», а затем нажмите «Перезагрузить». В следующем меню отображается 9 вариантов запуска, из которых вы можете выбрать! .Вы должны выбрать опцию «Отключить принудительное использование подписи драйверов», нажав «7» на клавиатуре. Теперь Windows запускается без проверки подписи драйверов. Это только временно до следующей нормальной перезагрузки. Итак, после выбора «7» окна загружаются без проверки подписи dirver. 4.) Установите драйверы: теперь подключите поддерживаемый DJI Remote через USB к компьютеру. Зайдите в «Диспетчер устройств» Windows. Там вы увидите одно или два новых устройства с желтым треугольником в списке. Для меня это показало "CDC ACM DATA" как новое устройство. Правый клик по нему. Выберите «Обновить драйвер» и выберите папку драйверов, которая находится в папке «DJI Assistant», где вы установили «DJI Assistant». Нажмите «включить все подпапки» и нажмите «Далее». Теперь вас спросят, действительно ли вы хотите установить соответствующие драйверы. Нажмите на ДА, и драйверы будут установлены. Теперь запустите симулятор и проверьте, правильно ли работает пульт. Должно. Это то, что я сделал, чтобы мой Mavic Air Remote работал с симулятором.
Добавлено позже (24 Декабрь 2018 - 01:46)
и в комментариях к видео:
вот что сделало это для меня: я был настроен скептически, но заставил его работать. Я нашел DJI_USB_5512_64_108.exe в c: \ program files (x86) \ DJI Flight Simulator и запустил его, когда мой контроллер Mavic 1 включен и подключен к моему компьютеру. Проверено, что в диспетчере устройств мой com 3 usb теперь говорит DJI USB Virtual COM (COM 3)
#26 OFFLINE
Отправлено 25 December 2018 - 06:32 PM
У кого-то получилось запустить на Маке ?
#27 OFFLINE
Отправлено 12 February 2019 - 07:47 PM
Тоже загрузил и установил симулятор. С пультом Mavic pro не удалось установить соединение. В FAQe написано, что поддерживается пульт Mavic Air(( Pro’шку забыли уже(
Хрень какая-то, в спецификациях есть Мавик про среди совместимых с симулятором, а ниже написано, что его пульт не поддерживается...Начинает напоминать Эппл, чтобы чем-то, но придушить старые модели...
#28 OFFLINE
Отправлено 15 February 2019 - 07:27 PM
Всё работает. Пульт мавик про.
#29 OFFLINE
Отправлено 15 February 2019 - 09:31 PM
И что, удалось нормально посимулировать?
Всё работает.
Снес как бесполезную прогу. Никакого соответствия с реальным поведением дрона.
Если бы Мавики на самом деле себя так вели, только у единиц получилось бы его не расколотить
#30 OFFLINE
Отправлено 20 February 2019 - 11:53 PM
жаль, что Phantome 3 Advanced не поддерживает.
Пробовал родной симулятор - очень примитивный.
Сейчас буду гугглить альтернативные симуляторы для Phantome 3 Advanced
#31 OFFLINE
Отправлено 10 March 2019 - 11:48 AM
У меня мавик эир, но пульт рисуется фантомовский, при обучении просит нажать кнопку которой на эир нет, по этому дальше пройти не могу, там что-то с переключением на минимап связано. Кто нибудь разобрался, что надо делать при свободных полётах, там над домами нарисованы коптеры, а что в этих местах делать, не понятно,
#32 OFFLINE
#34 OFFLINE
Отправлено 09 May 2019 - 06:22 PM
а как посмотреть видео которое записал при полете?
#35 OFFLINE
Отправлено 13 September 2019 - 08:29 PM
при подключении пульта от Фантом 4 Про, проблем нет, все переключатели норм.
При подключении пульта от Мавика 2 - проблемы, стики работают, кнопки - нет.
В чем может быть трабла?
Это лечится?
