Yuneec Mantis Q
Yuneec Mantis Q Yuneec Mantis Q
Сообщений в теме: 11
  #1 OFFLINE   ACDS
  • 3610 сообщений
Отправлено 07 August 2018 - 01:39 PM
Знакомимся с новым дроном компании Yuneec
Yuneec Mantis Q
Mantis Q – the foldable travel drone for small and big adventures alike.
It listens to you thanks to voice control, and the visual tracking will let it follow you wherever you go. Mantis Q’s energy-efficient design keeps in the air for up to 33 minutes and provides you with extraordinary photos and video clips from above. Just smile at your drone if you like –if activated, the face recognition let it take a picture of you as soon as it “sees” your face in a distance of up to 4m.
The integrated camera can be tilted up to 20° upwards and 90° downwards during flight. For cinematic camera flights, we also equipped the Mantis with automatic flight modes such as Journey or Point of Interest.
Whether you travel the world in a camper or make the Mantis your daily companion, the Instant Sharing function allows you to post your photos and videos directly from the app to social media so that your friends can get a glimpse into your adventures.
The Mantis flight controller is based on the familiar open source project PX4 which is known for being extremely stable and reliable. No video, photo or telemetry data is transferred unintentionally to any external server. Your data belongs to you!
The Mantis takes pictures with a resolution of 13 MP in JPEG or in DNG format and saves them on the included MicroSD card. The same goes for the up to in 4K recorded videos. Videos up to 1920x1080 (1080P) are electronically and live stabilized over all three axes. The Electronic Image Stabilization System is energy-efficient, solid and does not require fragile mechanics. 5.jpg
KEY FEATURES
  • Foldable
  • Up to 33 min. flight time
  • 4K video resolution, up to 1080p with image stabilization
  • Voice control
  • Flight modes: Journey, Point of Interest
  • Visual tracking
  • Up to 72 km/h (Sport Mode)
  • Instant Social Media posting
  • GPS or Indoor Positioning
  • Quiet and energy-efficient
  • PX4 based flight controller
TECHNICAL SPECIFICATIONS   DRONE
Takeoff Weight: 480 g
Flight Time: up to 33 min (in no wind environment at a constant speed of 25 km/h), 30 min hover
Dimensions:
250 x 187 x 58 mm (LxWxH, unfolded), 168 x 96 x 58 mm (LxWxH, folded)
Max. Ascent Speed:
Angle/Manual Mode: 10.8 km/h
Sport Mode: 14.4 km/h
IPS/Phone Mode: 7.2 km/h
Max. Descent Speed:
Angle/Manual Mode: 7.2 km/h
Sport Mode: 10.8 km/h
IPS/Phone Mode: 3.6 km/h
Max. Speed (Horizontal Flight):
Angle/Manual Mode: 21.6 km/h
Sport Mode: 72 km/h
IPS/Phone Mode: 14.4 km/h
Battery: 3S 2800mAh, changeable
Range Transmitter:
800 m (CE Norm, optimum conditions), 1.5 km (FCC Norm)
Operating Temperature: 0° - 40°C
Satellites: GPS, Glonass
REMOTE CONTROL
Channels: 10
Video Transmission Distance: 1.5 km (FCC Norm, optimum conditions), 800 m (CE Norm, optimum conditions)
Battery: 1S 3,7V 3000mAh Li-Ion, built-in
APP
Required Operating System: iOS 9.0 or above (Voice Control iOS10 or above, Voice Control with local processing iOS11 or above) / Android 5.0 or above (Voice Control requires internet connection)
CAMERA
Sensor: 1/3.06 inch CMOS
Photo Size: 4:3 (4160x3120); 16:9 (4800×2700)
Video Resolution:
4K: 3840 x 2160 30fps
1080P: 1920 x 1080 30fps
(with image stabilization)
1080P: 1920 x 1080 60fps
720P: 1280 x 720 60fps
Poto Format: JPEG / JPEG+DNG
Video Format: MP4 / MOV
Video Stabilization: 3-axis stabilized
Controllable Range (Pitch): -90° to 20°
FOV: 117°
Equivalent Focal Length: 21.5 mm
Compatible SD Card: Class 10 or U38/16/32/64/128G
ISO: 100 – 3200
Electronic Shutter: For Photo Mode: 8s-1/8000s / For Video Mode: 1/30-1/8000
Exposure Values: 0, ±0.5, ±1.0, ±1.5, ±2.0, ±2.5, ±3.0
White Balance: Auto, Lock, Sunny, Cloudy, Fluorescent, Incandescent
Scene Modes: Nature, Saturation, RAW, Night, Soft
Metering Mode: Spot Metering, Center Metering, Average Metering
Photo Modes:
Single Shot, Face Detection
Downloading Speed Photos:
1 MB/s
YUNMQEU
Mantis Q
Mantis Q, Controller, Battery (1 pc.), Spare Rotor Blades (1 set), Screws (8 pcs.),
serial 3-port charger, power and USB cable
499,- € RRP
YUNMQBEU
Mantis Q X Pack
Mantis Q, Controller, Photobag, Battery (3 pcs.), Spare Rotor Blades ( 2 sets), Screws (16 pcs.), serial 3-port charger, power and USB cable
599,- € RRP
  #2 OFFLINE   Parcifall
Parcifall
  • 1898 сообщений
  • Коптер:Mavic air/pro
Отправлено 07 August 2018 - 06:07 PM
1,5 километра в fcc...
Грустно
  #3 OFFLINE   costarika
costarika
  • 777 сообщений
Отправлено 08 August 2018 - 08:07 AM
не состоявшийся бриз 2?
стабилизатор на камере отсутствует...позорище
PX4 воткнуть можно, а стаб хоть 2х осевой - нет...
Добавлено позже (08 Август 2018 - 08:04)
https://fccid.io/2ACS5-YUNMQA мощя 150мВт, h480 с такими же мощностями на 2-3км летает (речь о видео линке)
Добавлено позже (08 Август 2018 - 08:07)
в промо есть куски снятого с Mantis Q
https://youtu.be/g3BaouOQk0k
  #4 OFFLINE   costarika
costarika
  • 777 сообщений
Отправлено 29 August 2018 - 01:35 PM
за такие деньги и без стаба - "не взлетит". даже офицалы наверно не повезут))
https://youtu.be/OM33r1sefe0?t=25
Сообщение отредактировал costarika: 29 August 2018 - 01:35 PM
  #5 OFFLINE   None
None
  • 332 сообщений
Отправлено 30 August 2018 - 10:40 PM
Ну вот скажите, откуда такой скепсис? После старта на "дурочка" цена упадет до приемлемой для Россиянина и повезут ))
Хотя я лично жду Рэйсера. Даже предзаказ сделал ))
  #6 OFFLINE   costarika
costarika
  • 777 сообщений
Отправлено 01 September 2018 - 12:42 PM
скептис от большой цены и ненужной камеры. кто "это" покупать будет?
что там сценами? usa - 500$? европа (как обычно) 450евро? а сколько спарк стоит?
  #7 OFFLINE   None
None
  • 332 сообщений
Отправлено 13 October 2018 - 02:47 AM
Инсайд говорит о том, что в России на данный летун появились запчасти. Буду брать как игрушку, вместо бриза, хотя ждал рейсера. Даже предзаказ на рейсер сделал :)
Кстати на этой игрушке вполне серьезный контроллер - PIXHAWK 3, что и привлекло мое внимание. Я думаю не смотря на то что камера без стабилизации - конструктор годный :)
  #8 OFFLINE   ACDS
  • 3610 сообщений
Отправлено 13 October 2018 - 03:19 AM
None
Вы решили конкретно добивать тестировать именно эту компанию по всем дронам. )
  #9 OFFLINE   None
None
  • 332 сообщений
Отправлено 13 October 2018 - 09:50 AM
ACDS, ну не только ее ) есть и других производителей. Только про диджеев и без меня писателей вагон.
  #10 OFFLINE   costarika
costarika
  • 777 сообщений
Отправлено 17 November 2018 - 04:52 PM
Глядя на потрошка новой версии Yuneec Pilot можно ожидать изменение модели)
  #11 OFFLINE   None
None
  • 332 сообщений
Отправлено 10 January 2019 - 05:50 PM
Попал он мне в рученьки :)
Могу сказать следующее - крут звереныш. Контроллер от 3DR это вам не хухры-мухры. Летает очень хорошо. Режим спорт превращает его в рэйсера. Несмотря на отсутствие стабилизации камеры снимает сносно (лучше бриза). Время полета даже в -14 очень хорошее - успеваешь замерзнуть раньше чем батарея закончится. После бриза летать не комфортно - через 10 минут постоянно смотришь на батарею, а она все не заканчивается при этом батарейка коптера и пульта заряжается очень быстро (пульт USB-C). Пульт к телефону конектится через USB/UCB-C. Софт не валится, автоматом приземляется +-20 см от места взлета.
И вопреки предыдущему утверждению - не стоит он своих денег сейчас,  либо должен подешеветь, либо подвес должен присутствовать.
Собственно он сам:
А это с него JPEG без корректировки:
Сообщение отредактировал None: 10 January 2019 - 06:02 PM
Добавил фото
  #12 OFFLINE   costarika
costarika
  • 777 сообщений
Отправлено 22 June 2019 - 10:48 AM
mantis g....опять без стаба камеры? видимо последнюю букву можно говорить уничижительно - гэ
и ни одного обзора https://www.youtube....is g"&sp=CAI%3D
Сообщение отредактировал costarika: 22 June 2019 - 10:51 AM
Темы с аналогичным тегами Yuneec, Mantis Q, Yuneec Mantis Q
