Прошился на последнюю прошивку и теперь не трогая стики мавки ведет в сторону как откатить назад прошу или есть ли может решение проблемы?
Сообщение отредактировал bopoh: 30 июля 2017 - 07:33
Отправлено 30 июля 2017 - 07:33
Отправлено 01 августа 2017 - 12:35
Та же история и уже месяц не вылечить. Зачем обновлялся?
Отправлено 01 августа 2017 - 01:13
Сообщение отредактировал RGT: 01 августа 2017 - 01:17
Отправлено 01 августа 2017 - 03:55
RGT, Backup your Dji's drone firmware, Keep it save, and downgrade, upgrade to whatever firmwares !!! even the pulled off versions by Dji.
First of all, thank you for geniuses people all over the world, especially for pOv, the_lord, hostile, jezzab, and many others including peoples who contributes inside dji rev slack group.
Software that you need ( noob mode )
1. DUMLdore by Jezzab download link : https://github.com/j...hive/master.zip ( last known version = 1.76 )
2. dji_system.bin ( drone or rc or gogles) long live github!!!
3. Dji Assistant software (preferably stable version)
https://github.com/M.../dji_system.bin
Okay. Let's begin!
1. Backup your current firmware, you can backup the drone fw, rc fw, even goggles fw
2. Extract the DUMLdore master
3. Go to extracted Folder.
4. Make sure you're not running dji assistant
5. Connect your powered drone to your pc wait a few seconds until your pc recognize your drone ( fully start up ) .
6. Open DUMLdore.exe
7. Press Backup Firmware button and wait the status complete.
8. You will have new dji_system.bin file Inside the DUMLdore master extracted folder.
9. Store that file securely and you can organize the file the way you need.
It's safe to disconnect your drone or you can....
Flash the firmware as you pleased!
Warning.
Use full battery or more than 50 % battery.
You can download the firmware from the link above.
Just like backup, you can just choose Load Firmware first and browse the firmware do you want to flash ( dji_system.bin ) and Flash Firmware button to proceed.
This process will take a while , and be patient. You can also use assistant to see the progress once when dumldore status green is full and it says "Firmware Uploaded" . The drone will restart a few times, don't disconnect the cables while doing it.
You can hear the sound of your drone if the process finish. And don't panic.
Happy Trying Firmware that you need Guys. !!!!
Ps: make sure you choose the right firmware also the right devices options on DUMLdore.
Here's the raw video that i made. I did backup, flash to downgrade, flash to roll back my mavic in one row
https://youtu.be/pV6wLPaxxH0 Я не бум бум в АГЛ
swinopass,Да кто знал то что ПОДСУНУТ лажу в новой проше((( я вроде откатил на 800 прошу, результат тот же
Отправлено 01 августа 2017 - 04:39
Отправлено 01 августа 2017 - 04:42
Какую лажу подсунули то? Проясните пожалуйста!
Сообщение отредактировал creep: 01 августа 2017 - 04:42
Отправлено 01 августа 2017 - 05:03
Отправлено 01 августа 2017 - 05:17
Стики не колибровал. Сегодня откалибрую. была прошивка 800 мавик лежал месяц включил обновил на 900 вышел на улицу заметел что плывет
creep,Лажу в виде новой прошивке после которой появился геморой
Отправлено 01 августа 2017 - 05:59
Сообщение отредактировал Игорь: 01 августа 2017 - 06:00
Отправлено 01 августа 2017 - 06:04
Калибровал и стики, и все остальное. Подвес рандомно выбирает направление и медленно плывет в какой-нибудь бок. Иногда не плывет) Короче, делает что хочет, зараза)
Отправлено 01 августа 2017 - 06:07
bopoh, в соседней ветке по вашей просьбе сделал ответ на ваши мольбы, а вы так по английски что то написали что после этого не хочется оказывать помощь когда ее просит такой образованный человек ,Создали новую тему... помощь в познании прописных истин. Это мое мнение ,
Сообщение отредактировал apm: 01 августа 2017 - 06:16
Отправлено 01 августа 2017 - 08:04
Калибровал и стики, и все остальное. Подвес рандомно выбирает направление и медленно плывет в какой-нибудь бок. Иногда не плывет) Короче, делает что хочет, зараза) ВОТ 1 в 1 отколибровал стики не помогает! откатил на прошивку 800 не помогает((( ранще не замечал.Такое ошушение что горизонт выравнивает, заметил что на малеккой выосте этого нет
apm,Спасибо за отклик я дейстительно ценю потраченно время на меня.КАлибровка не помогла
Отправлено 01 августа 2017 - 08:42
Отправлено 02 августа 2017 - 12:08
тоже плывет) я уже привык и даже использую как динамичную камеру, иногда только не в ту сторону плывет
Отправлено 02 августа 2017 - 03:37
Немножко не в тему, но у меня так и мавик и фантом 4 плывет. Иногда плывет иногда не плывет. Стики, IMU, компас - калибровано, летаю больше 4 лет, со всем этим уже давно подружился) В статике снимаю крайне редко, так что за проблему не считаю. А вот для фото с выдержкой приходится включать сетку и по ней ориентируясь компенсировать по YAW стиком что бы фото получить.
Отправлено 02 августа 2017 - 10:41
bopoh, В полётном меню заходите в меню настроек (правая верхняя иконка) далее тапаете иконку подвеса - там будет команда автокалибровка подвеса - жмёте и подтверждаете команду. Коптер должен находится на ровной поверхности и в процессе процедуры его не трогать.
